I acquired this machine to try and fix! Model number ZKN7147J. Machine wont fill upon start. If i manually fill it with a bucket, the valves then kick in to top up. The program carries on, spins out but then wont fill again for the rinse. Water is taken in for the dryer though. It also took in water for the 90 degree wash cool down??!! I have had the machine apart today, cleaned all pipes and filters. Ive checked all wiring also. Im guessing it needs a new inlet valve but feel its not really worth it for the age of the machine. Anyone any ideas? Could it be the PCB? Thanks in advance.
If it's a double or triple solenoid water valve one of the coils could be open circuit. Disconnect the machine and check the continuity of all the water solenoids which should be the same.
