Hello, I have a Bosch Vision 300 Washing Machine (WFVC4400 UC/24). I've started getting a E01 code recently and decided to replace the door latch with a brand new one. I'm still getting the E01 code after installing the new latch. I ran a test and got a C06 code. I also checked all the drain tubes/boots and pump. I also made sure all the wire harnesses were clipped in tight. Is there anything else I should try? Thank you for any help!
Travis
