Malcolmp121 Posted June 16, 2015 Posted June 16, 2015 Hi, I have error E40 on Electolux EWG1440W washing machine and the door interlock switch is black so I guess I need to replace this. The bit that goes into the interlock switch is also black. Does anyone know what this part is called so that I can buy this part too? Product no: 914511300 Serial number: 815 00150. Thanks.
Root Admin Whitegoodshelp Posted June 17, 2015 Root Admin Posted June 17, 2015 Error E40 "Door open, Interlock, wiring, or main PCB", so although a faulty door interlock is the most likely it's not necessarily the fault.The part that fits inside the interlock shouldn't need replacing unless it is obviously broken, in which case the door interlock may be ok because the door catch's job is to fit inside the interlock and activate it. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
