DaZzZzA Posted May 1, 2015 Posted May 1, 2015 Hi All Have had a look through Several topics to try and diagnose my fault but none seem too match Just wondered if anyone else had any ideas. I have a Washer / Dryer combi Indesit IWDE12 It had done a cycle and when I came to take the washing out it was soaking wet, so put back in and tried to do a dry cycle but nothing would start. Rang tech guys they said filter pump has gone so ordered new part and replaced. Now when I turn machine on it lights up as normal But if I try and start a wash cycle you can hear the door lock kick in but then nothing else happens? If I try going onto a dry cycle to test that it just reset's and I have too power off or hold reset button in. The door lock mech was replaced about a year ago. Any ideas would be much appreciated as I'm a bit baffled as too what too look at next. Many thanks
Root Admin Whitegoodshelp Posted May 2, 2015 Root Admin Posted May 2, 2015 On many Indesit washing machines an open circuit motor can cause everything to go dead. All the lights work and door locks but nothing happens. That's one possibility. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
edhorwood Posted May 3, 2015 Posted May 3, 2015 It seems a bit strange that fitting a new filter pump made matters worse? are you sure you didn't disturb any wiring? You could also try taking the clear plastic tube off the pressure switch, which runs up the side of the drum somewhere. Blow down the tube as hard as you can into the drum to remove any debris and try again.
DaZzZzA Posted May 3, 2015 Author Posted May 3, 2015 Thank you for the replies I will open it back up and see if can find this pipe and clear it also will check wiring, when you say open circuit is there an easy way to identify this on the main board? Many thanks
Root Admin Whitegoodshelp Posted May 11, 2015 Root Admin Posted May 11, 2015 An open circuit motor is most commonly caused by worn carbon brushes. There's nothing to check on the main PCB board. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
