thempsc Posted February 18, 2015 Posted February 18, 2015 Hi folks, I have with me a beko WM5100W with an error, but not sure of the fault. On any cycle, I get water pumping into the inlet as norma... Only for around 5 seconds, then it stops filling, and then drains for 1 second then nothing else happens.
Root Admin Whitegoodshelp Posted February 18, 2015 Root Admin Posted February 18, 2015 It looks like it might be quite an old washing machine. And if so it could be hot and cold fill. Are there two water valves or just one? It could be that one of the water inlet valves is not letting in water either because of a faulty tap or kinked hose, or a faulty water valve solenoid. The latter can happen with double cold fill valves where one side works okay but the other doesn't. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
thempsc Posted February 18, 2015 Author Posted February 18, 2015 It has only one cold fill connection, but two solenoids connected to that
Root Admin Whitegoodshelp Posted February 18, 2015 Root Admin Posted February 18, 2015 Try the machine on several different wash cycles and see if any water ever gets taken in by the second valve. It sounds to me as though the second valve may be faulty (possibly an open circuit coil inside) If you have a continuity test meter you could try disconnecting the machine from the mains, taking the wires off each side of the solenoid and checking to see if there's any continuity. The continuity reading should be the same for both valves. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
