Pughey88 Posted January 30, 2015 Posted January 30, 2015 My beko wm95135lb is 14 months old. For some reason, once it gets to the spin and drain cycle, it spins for about 2 mins, then the timer resets itself by 2 mins, and it repeats the process. The clothes are coming out soaked (but not wet enough that they can be wrung out) Any ideas? There's no issue with drainage because during the was cycle the water drains fine. No idea what it could be! HELP!
Root Admin Whitegoodshelp Posted February 3, 2015 Root Admin Posted February 3, 2015 When you say it spins for 2 minutes do you mean spins, or do you just mean it revolves slowly? Reply depends on this clarification. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Pughey88 Posted February 3, 2015 Author Posted February 3, 2015 HI The Machine attempts to spin for 2 minutes, and then it stops and resets. It has the capability to spin as i have put a wash on with no clothes in with limescale remover inside and it spins fast as it should. its only with clothes in when it has trouble. Thanks
Root Admin Whitegoodshelp Posted February 4, 2015 Root Admin Posted February 4, 2015 Hello, before a full spin there is a distribution period where the drum should revolve slowly for a couple of minutes trying to settle the load into a nice balanced load. If it does this first but then instead of kicking into a big spin just clicks and turns off then a blocked pump, or blocked or faulty pressure system could be the cause. There are other causes too. This is the article you need to read carefully to get a better idea. If it doesn't help the best thing is to get an engineer - won't do the fast spinHello, before a full spin there is a distribution period where the drum should revolve slowly for a couple of minutes trying to settle the load into a nice balanced load. If it does this first but then instead of kicking into a big spin just clicks and turns off then a blocked pump, or blocked or faulty pressure system could be the cause. There are other causes too. This is the article you need to read carefully to get a better idea. If it doesn't help the best thing is to get an engineer - won't do the fast spin Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
