Pigsfoot Posted January 15, 2015 Posted January 15, 2015 Hi, We have an Indesit IWC6105 washing machine around 3 years old. The drum has stopped turning. It did have a moment where all the lights flashed on the front console and the manual said to turn it off at the plug for a moment and switch it back on again which we done. The lights stopped flashing but didn't do much else to help fix the problem. I have taken off the rear panel and the belt is still attached and ok although it does seem quite easy to rotate the drum, ie not a lot of friction. When we set the machine to spin only the programme starts, the door locks but nothing happens, you can hear a couple of clicks as if something is trying but the drum does not turn. Indesit want over £100 to come out and have a look then parts plus labour to fix it or I could sign up to a £15 a month plan to repair or replace it. I am considering just getting a new... NOT indesit machine unless anyone on here has any ideas. Thanks
Root Admin Whitegoodshelp Posted January 16, 2015 Root Admin Posted January 16, 2015 This article is designed to help with washing machine drum not turning and contains mention of (and a link for more info) the possibility of worn carbon brushes which is a very common cause of the motor not running (though not the only possible cause). Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
