Hi there I have a beko excellence there has been a problem with draining and on the last spin the are excessive suds and washing still wet machine still spinning perfectly had pump replaced but still having the same problem has anyone got any advice thank you
I would suggest the following two articles might be relevant.
What causes too much foam in the washing machine?
Washing Machine Won’t Drain Water
