Hi There
I wonder if you can help me.
My washing machine drum will not turn at anytime. I have checked the belt and it is ok. The motor (Nidec 20584.453) is at the bottom and does not appear to have any symptoms of burning and no loose wires. I see that there are brushes but these look rather difficult to remove without removing the motor itself
Would be grateful for any advice
Thank you
Ralph
Hi Ralph, I have all advice about this fault here - Washing machine drum not turning. Unfortunately if it can't be fixed from the clues in the article it needs an engineer. Some brushes can be removed with the motor in place but some really need the motor taking off.
