Hi there hope you're all well.
I've got a ZWH 6120p that's refusing to start washing after packing up halfway through a cycle. . Turn the program dial and press go and I receive a series of red flashes on the LED on the start button followed by green flashes.
Now I've counted them and it's 11 RED followed by 2 GREEN. I did a little bit of basic Googling and found this site :
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3068-zanussi-washing-machine-error-codes.html
The error code there would mean mains voltage too high however the fascia panel doesn't match up with those & I can't find a diagnostic manual for the 6120P anywhere so I am assuming it's not correct. Plus I've swapped the socket & plug over to check if it was an electrical issue to another plug and socket which was working on the drier and freezer fine. No issues.
I did have a clicking noise issuing from the washer as though the pump was struggling to turn over however this has now (scarily) ceased.
Does anyone know the error code read out for 11 red 2 green on this model or have any ideas?
Many thanks
