gp1991 Posted December 18, 2014 Posted December 18, 2014 Hi there, I think that the settings are out of sync, as when i go to select spin, it fills rinses but doesn't spin it also takes about an hour to run through and i cant cancel. The spin seems to work on my normal washing setting. Is there anything i can do to fix this? I cant really afford to have an engineer to come out. Thank you Gemma
Root Admin Whitegoodshelp Posted December 19, 2014 Root Admin Posted December 19, 2014 The way to tell is, if you turn the selector switch to "OFF", does it do anything? If the selector switch is out of sinc it will be out on off too. If it does something on off, try finding the one position where it does nothing and that is the Off position so you could work out how out of sinc it is. If it was one position out for example it could be that selecting spin is actually selecting the rinse cycle one position before. If the off setting is correct and when you select off nothing happens then it can't be out of sinc. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
