Traingrader Posted November 10, 2014 Posted November 10, 2014 I replaced the door interlock with no change in display . Then found some coins in the pump filter and this seemed to cure problem. Worked for 3 cycles and now "door" is on display again and although door locks/unlocks when switched on/off the cycle will not start. Pump filter is clear.Any ideas?
Root Admin Whitegoodshelp Posted November 10, 2014 Root Admin Posted November 10, 2014 The only fault coins in the pump could cause is to stop the pump working leaving the washer full of water so that was a read herring. This article covers general help on how does a washing machine door interlock work? and this may help too washing machine won't start Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
