I have a beko wmb81241lb needs resetting ,it just fills up and turns around but wont spin etc or finish cycle,any advice much appreciated,it is showing error e08 when I press the start button to reset ,anybody know what that means regards lisa xx
If it is detecting an error it can't be re-set until the fault has been fixed. Unfortunately I don't have Beko error codes (despite having a book of error codes) so unless there are other clues it's impossible to know where to look. That's what I hate about error codes, they trap errors so no one can repair a machine unless they know what the code means and more and more manufacturers keep them as secret as possible.
If it isn't pumping the water out you could troubleshoot why, which might clear the error. Otherwise you'll need an engineer or the meaning of the error code.
