kristal17 Posted September 25, 2014 Posted September 25, 2014 Hello kind people, My problem with the above machine is that the drum wont turn during a wash/cycle/spin etc. The machine makes all the usual gurgle noises as if all is normal, but the drum will not turn itself I have checked: The sump pump and the drain hose and emptied out any gunk The belt hasn't snapped and as far I can tell hasn't came off the pulley The drum will turn if you manually turn it with your hand When it was going fine earlier today, there were some concerning noises and it didnt sound great, so I am unsure if it is an electrical fault. I left it off for a while and it turned for about 5 seconds then stopped. Does anyone have any ideas or came about this type of problem? Many thanks in advance, Kris
Root Admin Whitegoodshelp Posted September 26, 2014 Root Admin Posted September 26, 2014 Hi Kris, There's no simple common cause but I have a full article on this here - Washing machine drum not turning Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
