Our Bosch Exxcel 1600 gives error code F04.
We check the pump - nothing blocking impeller.
Try again - F04. We check pump and outlet are clear.
Try again - F04.
Is there a cheat we can use to get a few more months use out of the five or six year old machine?
There are lots of different error codes for different models. What is the proper model number?
I don't have the WFX range :( The only Bosch F04 error codes I have say "motor fault". It's possible this isn't relevant to your model but generally they often keep the same codes from machine to machine but definitely not always. The only thing I can suggest is to check the motor for connections faults and check the carbon brushes or get an engineer.
