Greetings!
My Performa was smelling musty even after running several cycles of hot water with Affresh™, so I decided to take off the tub top and have a look. This is what I found.
(If you can't see the image, the entire underside of the tub cap is covered in a thick mat of crud.)
How does dirt get up into the tub top in the first place? The water level's never supposed to go that high, is it? But it must have been happening consistently for years to accumulate that kind of buildup...
post-2676-0-23320800-1399840571_thumb.pn
That's nasty. My article here explains a lot about the causes of build up of grime and grease inside washing machines
Do you use mostly low temperature washes, use reduced detergent quantities and/or liquid detergent?
