Polygono Posted March 22, 2014 Posted March 22, 2014 Hi Guys Can anyone identify the fault that stated to happen on my washer dryer machine its very noise on the spinning cycles. http://youtu.be/cxF0uSrbVww
Root Admin Whitegoodshelp Posted March 23, 2014 Root Admin Posted March 23, 2014 It could be a loose tub weight. See if you can track it down by making it noisy - unplug it, take the top off and shake the tub around or check to see if any of the weights are loose. Also check out this article which gives lots of possible causes of noises It sounds like something somewhere is loose. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Polygono Posted March 24, 2014 Author Posted March 24, 2014 Thank you. You were 100% correct it was the front tub weight. All sorted Thank you so much for you help Whitegoodshelp 1
Root Admin Whitegoodshelp Posted March 25, 2014 Root Admin Posted March 25, 2014 Nice one If it comes loose again you will need to do something to stop it working loose. Undo the nuts enough to get loctite on the thread and try that. You have to tighten them firmly but must be careful not to over tighten because it can snap the bolt or break the (often) plastic housing the bolt is slotted through. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
