machineage Posted March 22, 2014 Posted March 22, 2014 Hi all I have a problem with the above mentioned washer On power up (selecting a program) the door security LED remains statically lit - it should ordinarily flash until the start button is pressed - whereupon the interlock activates and the machine starts filling etc... I thought it could be the interlock - so I replaced that - but no change. On occasion in the past if you rotated the program dial - the door security LED would flash and it would start the program. Of late though nothing seems to get it to start. When it did start - it ran through the program fine with no errors. The different programs still display their relevant spin / temperature LEDs when selected by the dial - and when you press the start button - the stop button stops flashing and the relevant time LED lights. So all seems fine on the program select front. Any ideas?
Root Admin Whitegoodshelp Posted March 23, 2014 Root Admin Posted March 23, 2014 On some washing machines other faults can cause the whole machine to stop working such as an open circuit motor including carbon brush faults. If you can't see any carbon brush faults it'd be better to get someone in. http://www.whitegoodshelp.co.uk/washing-machine-wont-start/ machineage 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
machineage Posted March 23, 2014 Author Posted March 23, 2014 Hi there Thanks for the reply. If it were a motor fault I thought the machine wouldn't operate properly? As it is - when it does decide to kick in (door security LED flashing - press start & interlock activates / machine fills) it works just fine right though the programs. It seems to be something which is affecting the machine on power-up. I disconnected the heater (suspecting an earth leakage) and that made no difference. Similarly the inlet valves & pumps. Checked the board / connectors and re-flowed the majority of the joints. I've just not found anyone with a similar problem. Lots of people with constant door security LEDs flashing - but not one that remains lit on power up and remains lit
Root Admin Whitegoodshelp Posted March 24, 2014 Root Admin Posted March 24, 2014 The motor fault I described can cause all the lights to work but machine won't start. It's possible for the fault (if it was anything to do with the motor) to be intermittent so that sometimes it will work. The problem is intermittent faults are often a nightmare to troubleshoot, even for repairmen. machineage 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
machineage Posted March 24, 2014 Author Posted March 24, 2014 I would kiss you if you were a bit prettier !! Removed the motor and upon removing one of the brushes - the carbon was part seized in its holder thanks to the dust throwback. I loosen it and blew out the carbon dust with some compressed air - et voila - a working machine!! I will replace them anyway as they seem a little on the short side - which probably made the seizing more likely as there is less push from the spring. One more machine saved from scrapping - for now...! Whitegoodshelp 1
Root Admin Whitegoodshelp Posted March 25, 2014 Root Admin Posted March 25, 2014 Ha ha - lovely Good work. This article gives general advice on carbon brushes, it's written about Hotpoint / Creda brushes but the principle's the same for all brushes - carbon brushes diagnostics Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
