dylan_bhafc Posted March 21, 2014 Posted March 21, 2014 Hello, my first post. I have an issue with the above machine, it fails to drain water at the end of the cycle. I manually drained it using the hose at the front and found a hairclip that was caught in the trap (this was possibly stopping the drian motor from spinning). Tested another cycle but again it fails to drain. The pump is spinning (it's louder than normal) and I can see the impeller spinning if I remove the front hose drain cover. I can also confirm that the rear outlet hose is definitely not blocked. Is it most likely that the drain impeller pump motor has failed due to hair clip?? Is this a replaceable part and how much?? I would do it myself as I am an IT engineer and mechanic so not daunted by such things. Thanks in advance for any advice Dylan
Root Admin Whitegoodshelp Posted March 21, 2014 Root Admin Posted March 21, 2014 It's possible the impeller has broken and instead of spinning it's just rattling about on the shaft. If so it needs a new pump. Either that or there's a blockage somewhere else. Just double check everything in my article here - Can’t Find a Blockage But Washing Machine Still Not Draining Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
