Hi there
Can we have some help please.
We have a Zanussi FJ1254w washing machine which is going a bit crazy the washing machine has been coming up with error leds flashing 1 & 4 which requires pausing and skipping on..
Have run a clean cycle and we thought its settled somewhat better now its beeping again through the wash cycle but it does stop like when 1&4 were flashing?
Unfortunately we are back to the flashing 1&4 leds.
We have:-
  • Checked water feed all okay
  • Cleaned drain access on machine and cleaned out drain vertical stand pipe.
  • Drain pump working well with standard noise - drains fast!
  • Run a cleaning cycle!
Can you advise whats best to check?
