angie Posted October 15, 2013 Posted October 15, 2013 I have a hotpoint ultima washer which was displaying a F05 error. I cleaned the filter out (found 29p) and the pump is now working again but now it wont fill or spin and ticks off the minutes of a cycle. Any help woud be much appreciated!
Root Admin Whitegoodshelp Posted October 16, 2013 Root Admin Posted October 16, 2013 Error F05 means the pressure switch has "jammed" on preventing the signal that the water has pumped away successfully. This can be caused by a pump blockage, but if so, it should have a lot of water in. If the water pumps away OK, but you still get this error then it's not a pump blockage, it's a fault elsewhere. Suspects are the pressure switch itself is jammed, (i.e. the switch is stuck), or it's jammed on because a blockage in the pressure chamber bottle at the bottom of the thin tube which is connected to it is holding air pressure keeping the pressure switch on. Could even be connection issues or pcb issues but pressure system issues is most likely. Theres a lot on pressure systems in these forums if you search all forums for "pressure system". angie 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Root Admin Whitegoodshelp Posted October 17, 2013 Root Admin Posted October 17, 2013 I've just written a better explanation of this error on the main site - Hotpoint Error F05 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
