Hi
I've just fixed an electrical issue in my Bosch Exxel 1600 (loose wire) but I can't seem to get the error code to go away and use the machine again.
When I switch on the machine all of the red lights on the front are lighten up and the LCD display is lit but isn't showing any messages or icons.
Does anyone know any way to reset the error code on a Bosch Exxel 1600? Is there a specific combination of button presses?
Robert
Error codes should normally stop showing when the fault disappears. The symptoms you describe don't sound like an error code, they sound like a fault with the pcb or control panel or communication between them. I would get an engineer in to be honest.
