Hello everyone. I really hope I can get some help. I have a Beko WMB71642W Washing machine and up to now it has been fantastic. I run a small laundry business for holiday cottages so when I have a machine down I really struggle to keep up. The warranty on the machine ran out 5 weeks ago and all of a sudden I start getting issues!!
For some reason the machine has decided that it doesn't want to drain. There is no obvious blockage in the drain tube and no overflow of water from the pipe. The machine has a separate 'spin + drain' function but this is not working either.
Is this a common fault? Has anybody got any tips I could try as I dont have a clue where to start. Please help, I have got some very expensive towels that have been in there for 2 days now with some very frustrated clients!! :(
Any help or opinions are welcome
Big thanks
Hello, Beko are woefully inadequate for heavy duty washing, as are most modern washers. Many are only designed to last for a set amount of cycles which any heavy use, even for a normal large family, can be used up in 2 or 3 years. Hopefully it's just a blockage though and you might be able to fix it with help from this article - Washer wont empty water
