Mr-k Posted May 29, 2013 Posted May 29, 2013 Hello My washer dryer stops after ten mins or so into a dying cycle... this happened before under warranty and a helpful chap came and unclogged something inside that was full of fluff, the condenser chamber perhaps? Looks like I need to do this again, can anyone offer advice as to what I'm looking for? I had a look earlier today but couldn't see anything obvious! Thanks in advance, Ant
Root Admin Whitegoodshelp Posted June 11, 2013 Root Admin Posted June 11, 2013 Sorry Ant, it's not forced to be the same cause although it may be and I can understand why you'd assume it was. I try to give general repair advice rather than strip down instructions but I'm not familiar with your model anyway. I can explain how it works so if you can work out what to check from that it will be a help, if not you'd be better not taking things to bits to be honest. The dryer on a washer dryer is a condenser dryer so water should trickle into a condenser chamber when the steam from drying the laundry is blown as well. The steam hits the trickle of cold water and condenses back into water where it gets pumped down the drain. If the condenser chamber gets blocked at the bottom it can stop the condensed water running into the pump. If the water stops running into the chamber the steam won't condense and also cause a fault. Likewise if the fan stops running it won't pump the hot air into the chamber and of course if the heater stops working it wont dry them either. Then there are stats and thermal overload cutouts which can go open circuit and stop the heater from working. Don't touch the machine with it connected to the mains, some of these wires can be live even when the machine is not running. If it gets hot on dryer and the fan is running then the fault may well be to do with the condenser chamber. Check for the plastic condenser chamber at the back of the machine and make sure there isn't a blockage in the hose leading from the bottom to the bottom of the tub. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Mr-k Posted June 12, 2013 Author Posted June 12, 2013 Thanks very much for the comprehensive reply, Andy! I'll have another go, hopefully at the weekend!
