Jetprov Posted April 4, 2013 Posted April 4, 2013 Hi I have read the Hoover 1100 problems similar to this and disconnected the pressure switch tube, no change. The machine is emptying, it starts to try and spin up, I hear a relay click then click again and it stops for a few moments and tries again. Motor is working in both directions. Any help appreciated.
Root Admin Whitegoodshelp Posted April 5, 2013 Root Admin Posted April 5, 2013 Is it an old machine? On the older machines if you heard a click and then it stopped just when it should have gone into fast spin it was usually the pressure switch clicking. There isn't normally a relay involved on spin. Is it emptying the water out fast enough? Reduced pump flow often caused this problem. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Jetprov Posted April 6, 2013 Author Posted April 6, 2013 Hi, the machine is about 8 years old I seem to remember. I heard the clicking with the pipe from the pressure switch disconnected, the pump was working but now seems to have stopped, the machine fills with water and the drum has stopped rotating at all! Time for a new one.
Root Admin Whitegoodshelp Posted April 6, 2013 Root Admin Posted April 6, 2013 If the drum's stopped rotating it could be quite a lot of things, the most common is worn carbon brushes http://www.whitegoodshelp.co.uk/washing-machine-not-spinning-drum-not-turning/ Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
