Hi ,
I need to replace the door seal on my Indesit iwc6165ukc. I've tried doing it without removing the front but i can't get it on. I cant see how to remove the front or even if i can. any tips?
Replacing a door seal can be a lot trickier than you'd think depending on the machine (washer dryers are hardest). I've been to some where even as an experienced engineer I've struggled if you can't get the front off because of the lack of room to work. I'm sure the one I remember was an Indesit and couldn't get the front off. A nightmare. If the front comes off on your model you normally have screws hidden behind the soap drawer front and control panel as well as maybe behind the kick strip.
