I've just created a new article by combining and re-writing 3 different ones that were all on the same subject. It looks at the issue of non-standard washing machine heights, widths and depths, which many people find that they need due to having a washing machine space that is too small for a normal sized washer.
The article contains useful tips and possible workarounds on reducing the height of a washing machine. This article is now on my main white goods site (Whitegoodshelp)  - Washing machines and associated problems with sizes
  • Whitegoodshelp changed the title to Article On Washing Machine Sizes (looking for a smaller washing machine)
The standard European width for a washing machine is about 600mm. Most washing machines are either 600mm, or 595mm wide. Washing machines can vary slightly in depth and height but the most common washing machine height is 850mm. The depth of a washing machine varies much more and is usually less critical.
