Mak Posted February 7, 2013 Posted February 7, 2013 Hi, I have a hotpoint/indesit BHWD 129 integrated washer dryer which stops a few seconds after starting to pump out. The buttons lights flash and program lights 1,2,3 and 4 are lit (1 being the bottom door lock). for the few seconds the pumping works it seems to work fine and it is possible to empty the machine by restarting it (program "C") a few times. The filter in the bottom was also cleared. I understand the program lights indicate the error code but I can't find an online technical manual unfortunately and Indesit themselves refused to assist. Your assistance in identifying the problem would be greatly appreciated Many thanks Mak
Root Admin Whitegoodshelp Posted February 7, 2013 Root Admin Posted February 7, 2013 Are the flashes a set number? Flashing lights usually indicate an error code by flashing a set number of times, pausing, them repeating the sequence. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Mak Posted February 8, 2013 Author Posted February 8, 2013 Thanks Andy. I checked last night and the lights just flash continously at a constant rate. All button lights flash. the program lights 1 through 4 stay lit
Root Admin Whitegoodshelp Posted March 11, 2013 Root Admin Posted March 11, 2013 It's not indicating an error code then, which limits what you can try. Apart from checking the pump filter and plumbing for obstructions - Washing machine pump problems you need an engineer. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
