tg75 Posted January 27, 2013 Posted January 27, 2013 Hi, Im after a bit of advice on a Zanussi WDT1085 TurboDry. The machine starts to fill with water, then after about a minute it trips the RCD on the board. If I then click the dial on a bit so that its mid way through the cycle, it will run fine and complete the wash. Im thinking this might be happening when the heating element kicks in...can anyone confirm this please? Just want to make sure before I buy a new element. If anyone has a link to a manual that would be really appreciated too! Cheers :-) TG
Root Admin Whitegoodshelp Posted January 28, 2013 Root Admin Posted January 28, 2013 You can't get repair manuals for them. If the motor runs ok on the later section of the programme and spin then I would agree that the heating element is number one suspect, they often go down to earth. Without a proper insulation test meter though you can't diagnose it unless you found a wire near or on the heater had come off or was shorting out somewhere. The only thing you could try without a meter is to speculatively replace the heater. I have an article on tripping electrics Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
tg75 Posted January 28, 2013 Author Posted January 28, 2013 Thanks Andy Will try and borrow a megger and check the element and the wiring nearby. This is gonna be a laugh though; the shed its in is tiny and I put the machine in there before I fitted the door frame and door :D
Root Admin Whitegoodshelp Posted January 28, 2013 Root Admin Posted January 28, 2013 Sheds are normally a bad place for washers but I now you wouldn't have it there if there was room elsewhere. If it's damp in there it won't help insulation, condensation can be a problem too. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
tg75 Posted January 29, 2013 Author Posted January 29, 2013 Yeah, you're right Andy, no room elsewhere. It's a brick shed and is reasonably dry, but I will check inside for condensation. Cheers! TG
Root Admin Whitegoodshelp Posted January 29, 2013 Root Admin Posted January 29, 2013 When appliances are in places which get very cold the moisture they create when running can condense inside and cause problems although the fault you describe sounds more like the element has developed low insulation or there's an insulation problem with the heater wiring. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
tg75 Posted January 31, 2013 Author Posted January 31, 2013 Job done! No condensation or dodgy wiring but it's a funny job! Ended up with the machine in the garden propped up by the tool box to get to the element. Belt off and some brut force to move the drum over a bit allowed me to *just* get it back in. I'm sure I had it upside down at one point too! Took about an hour all in :-) Have photos if anyone needs a steer! Thanks for the help Andy! TG
Root Admin Whitegoodshelp Posted February 1, 2013 Root Admin Posted February 1, 2013 Nice one Feel free to post pics. I take it you managed to replace the heating element? It can be tricky to get the element out if you don;t realise how they are secured in place. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
tg75 Posted February 2, 2013 Author Posted February 2, 2013 Yeah I managed to swap it out... Was tricky due to the angle you have to put it in at because of the machine casing. Been off the tools for a few years now so enjoyed getting my hands dirty again :-) Whitegoodshelp 1
