Richstanton Posted January 24, 2013 Posted January 24, 2013 Hi, I have a hotpoint WF541 washing machine, and halfway through a cycle the 'door locked' light started flashing, the cycle stopped, and the only way to get the door open was to turn it off at the mains for a few minutes. If I tried to start a new cycle the 'wash'light came on and the door locked, however the door lock light didn't come on and the cycle wouldn't start. I figured the door interlock was broken, so bought a new one. I fitted it, and everything now worked perfectly. However after putting a new cycle on, it got halfway through the cycle and the same thing has happened again to the new door interlock. I.e. I press start cycle, the door locks but the door lock light doesn't come on. The cycle doesn't start and the only way to release the door is to turn the mains off for a few minutes. So, was I just unlucky and got a duff replacement interlock? Can the machine have a fault where it damages interlocks? Could the problem be something else, and it was just chance that it seemed to work after fitting the new interlock? Any help appreciated!
Root Admin Whitegoodshelp Posted January 25, 2013 Root Admin Posted January 25, 2013 The least likely explanation is the new door interlock has the same fault. If the door locks it indicates the door catch and interlock are being activated ok. After the door lock is activated it should pass power onto the rest of the machine through the main pcb so maybe there's a fault somewhere else on the machine or pcb. I would get an engineer in. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Richstanton Posted January 25, 2013 Author Posted January 25, 2013 Thanks for the reply, I've booked an engineer, I was just a bit confused that replacing the interlock seemed to fix it initially.
Root Admin Whitegoodshelp Posted January 28, 2013 Root Admin Posted January 28, 2013 Cheers, let us know what happens. You said it only fixed it until it got to the middle of the cycle where it failed last time so maybe the fault only occurs mid cycle. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
