kee Posted January 16, 2013 Posted January 16, 2013 My 12 year old hoover six 1100 door won't open after the wash cycle has finished. It will however, if I unplug it and leave it for a few hours. (I run the dryer as well, don't know if this helps) Why is this and can it be repaired, and at what cost?Someone suggested it might be limescale on the pressure pot (huh?) and I could clean the tubes myself! Really, how?
Root Admin Whitegoodshelp Posted January 16, 2013 Root Admin Posted January 16, 2013 If the door interlock has a rubber pressure tube connected to it then it could be a blockage in the pressure system preventing the air from escaping. Not all washing machines have them, but here's how the system works - The door interlock has an internal locking peg operated by air pressure When water goes into the tub some of it goes into a plastic compartment called a pressure chamber This pressure chamber has a small rubber hose connected to it which goes to a pressure switch to control water levels and sometimes to the door interlock too Water entering the machine forces air up this small tube and locks the door interlock When the water has pumped away water drains from the pressure chamber and releases the locking peg on the door interlock Sometimes a partial blockage in the pressure chamber (at the tub end) prevents or slows down the release of air pressure when the washer has finished pumping out the water so the door still won't open for an hour or more after.If your door interlock has a rubber tube attached to it follow this line of inquiry. If it has only wires connected to it then it can't be this, though it's possible the door interlock is sticking. See this article for general help with a door which won't open. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
