Curious Posted June 9, 2006 Posted June 9, 2006 I've got a problem with my Zanussi washing machine. History Drum stopped turning during cycle, I checked the motor brushes and they where badly worn so I replaced them. Drum is now turning. The problem is that after the spin cycle, the clothes are still wet. Sounds as if the water is pumping out down the drain, but it seems that spin cycle is very short approx 1min. Got any suggestions???
Root Admin Whitegoodshelp Posted June 9, 2006 Root Admin Posted June 9, 2006 Is it going into a proper fast spin? Or is it just doing the slow distribution bit which is supposed to allow time for the water to pump out and for the clothes to get balanced round the drum? If it's starting a proper spin, is the motor running OK or is it flashing and sparking? Just double check the obvious stuff like making sure the washing machine's on a full spin setting and no option buttons pressed in that can inhibit or reduce spin speed. ( Related spin problems: Washing machine won't spin or drum won't go round ) Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Curious Posted June 9, 2006 Author Posted June 9, 2006 It is spinning fast, however there is a clicking noise from the machine, could it be possible that I put in the brushes in the wring way around, could this cause the problem? (there was a point on the new brushes).
Root Admin Whitegoodshelp Posted June 9, 2006 Root Admin Posted June 9, 2006 The carbon brushes can be the wrong way round with this type of motor. If so, when turning the motor (via the drum) it can sound very noisy and make a funny ratchety sound because only the tip of the brush would be making contact. This could make the motor lack power. It should be noted that new brushes in a washing machine motor do often make a louder ratchity noise until bedded in, but if they are fitted so that the tip of the brush runs against the copper commutator instead of the curved face, it will be particularly pronounced. Another cause for a clicking sound could be if a segment from the commutator (the copper segmented section of the armature that the brushes run against) is coming loose and slighly raised. This can be detected by placing a finger on the commutator and slowly rotating the armature. Any raised sections should be felt through the finger tip. This type of clicking sound though would be one click, each revolution. Of course it should go without saying that the washing machine should always be unplugged! before taking the lid or back panel off. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Curious Posted June 9, 2006 Author Posted June 9, 2006 Hi Andy, Just a quick one to say thanks, it was the brushes, I swapped them around and everything is fine now!! thanks again,
