hello there, i have a candy go 1482 and the washing goes fine until it comes to the spin cycle and then comes up with the 90' and stain vanish lights flashing without spinning, a friend told me it could be the brushes but i think if they was gone the drum would'nt turn at all? sometimes it does spin but more often it dose'nt. any help would be brill. thank you in advance. dave
You need to report which numbers these lights are as described here http://www.whitegoodshelp.co.uk/washing-machine-lights-flashing/
hi there, thanks for your reply, ok i hope i get this right, led 1 (90') is flashing, and the next one i have i counted all the way left to right and then started ont he 2nd row which is the 11th led (stain vanish) or the 1st in the 2nd row. so its either led 1 and 11 or led 1 and 1. these flash 3 times with a pause then flash 3 times again. hope this helps. thanks again. dave
Sorry, no that's not what I'd normally expect. Are you counting just the bank of option lights and not every light on the machine?
