BrucieBonus Posted December 27, 2012 Posted December 27, 2012 Hello.. My Hoover Oph 716 DF has recently stopped working. Basically when the start button is pressed nothing at all happens.. Usually a led lights up when the start button is pressed or flashes if the door isn't closed properly.. Machine has power as display is still lit.. Other buttons still function as normal. I tried dismantling the machine to get to the buttons to see if I could try swapping them around but they're all soldered directly to the circuit board,, I've also tried unplugging/re-plugging in all the connectors on the circuit board but no joy there..Same with the interlock., No error numbers are showing up on the display. Machine is 2 years old. Any suggestions as to what I can try next? Thanks in advance,
BrucieBonus Posted December 31, 2012 Author Posted December 31, 2012 Well typically it's started working again by itself.. must have decided it wanted a xmas break!
BrucieBonus Posted December 31, 2012 Author Posted December 31, 2012 Spoke to soon.. It's not working again... anybody got any clues?
Root Admin Whitegoodshelp Posted December 31, 2012 Root Admin Posted December 31, 2012 Does the start button feel different to how it used to be? Or different to the others? It could be the button on the panel is faulty. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
BrucieBonus Posted January 2, 2013 Author Posted January 2, 2013 Does the start button feel different to how it used to be? Or different to the others? It could be the button on the panel is faulty. The buttons are soldered onto the circuit board so I can't swap them around or anything unfortunately.. It still gives a small click like normal.. It is working again at the moment although somewhat intermittently.. very strange..
Root Admin Whitegoodshelp Posted January 2, 2013 Root Admin Posted January 2, 2013 Intermittent faults are a right pain. If it does it again try this article - washer won't start Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
