jamiepscot Posted December 20, 2012 Posted December 20, 2012 Hi can anyone advise? Trying to get the front panel off but it appears welded on. I've removed the top panel and the front control facea and unscrewed every screw i found(10 in total). I need it off to change a torn rubber seal. Help????
jamiepscot Posted December 20, 2012 Author Posted December 20, 2012 Oh by the way I did contact Hotpoint, was put on hold and transferred to several departments, before finally being told....they no longer give technical advice!!!! Awesome!!!!
jamiepscot Posted December 20, 2012 Author Posted December 20, 2012 It doesn't come off, it is welded on!!!!! To change the rubber seal. Tilt the machine back, to make more room at the front, and just get your hand in to put the seal on. Have patience, it's a sod of a job!!!! To put the retaining spring back on. Put a screwdriver in the hole at the door catch. This will pin/hold the spring in place whilst you feed it on bit by bit. Enjoy!!!!! Whitegoodshelp 1
Root Admin Whitegoodshelp Posted December 21, 2012 Root Admin Posted December 21, 2012 Hello Jamie, thanks for posting your solution. Sorry you didn't find any help to save you being messed around by Hotpoint. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
