Hi hope someone can help.
The start/pause button on my machine won't work.
The digital display has the correct information for each cycle when selected and the other buttons respond as they are supposed to but the start button just continues to flash and won't respond when pressed. This is not a child lock issue which seems to be a common problem because all the other buttons respond appropriately and the display has no error message at all.
Would really appreciate a solution, cannot afford this bother at the moment.
It could be that the button on the pcb is faulty and needs replacing. Does it feel different at all when you press it? It should normally feel as though something underneath is clicking when you press it (maybe only very quietly). Does it feel any different to the other buttons?
