bandit5050 Posted August 14, 2012 Posted August 14, 2012 hi, I've got a hotpoint ultima 1400,when you close the door it says select program,which is normal,so you select program, press start and after a while it flashes up "close door" even though the door is full closed. I thought it might be the door interlock switch,so changed it but not worked,still does the same.any ideas .cheers ady
Root Admin Whitegoodshelp Posted August 15, 2012 Root Admin Posted August 15, 2012 It isn't getting the signal that the door is closed. If it's not the door interlock check that the interlock mechanism is actually being activated by the door catch when the door is being closed. It's always worth lubricating both with WD40, but check the door catch isn't loose or broken or has a broken spring and that the door seal isn't peeling away from the door opening rim in a small section which can prevent the door closing properly. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
