thecritter99 Posted June 5, 2012 Posted June 5, 2012 Hi, I don't know much about these things, but I've watched videos on YouTube over the last hour or so and they seem a lot more simple than I expected to fix them. My parents want to get a new one and I want to save the family money instead. Seems such a waste for what could be a simple fix. Basically, the washing machine trips the house electric. There is no sign of life whatsoever, however, the drum seems to roll freely when I move it with my hand. From what they tell me, it just cut out during a cycle after about 20 mins, tripped the electric, then when switched back on again, showed no life at all and again, tripped the electric. The socket isn't faulty, and the fuse has been changed so I know these can't be at fault. Any ideas? Thanks! P.S It is a Bosch Classixx 1000 (about 6 and a half years old)
Root Admin Whitegoodshelp Posted June 6, 2012 Root Admin Posted June 6, 2012 Unfortunately, unless you can see an obvious cause such as a wire off and touching something, or the plastic insulation on a wire rubbed away and touching something metal you can't fault find a washing machine tripping the electrics without a special (and expensive) insulation test meter capable of putting 500 v dc through the machine. I have an article in my washing machine troubleshooting section here - Washing Machine Fusing Electrics Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
thecritter99 Posted June 6, 2012 Author Posted June 6, 2012 Thanks for the reply... I'm going to have a look inside to see if it is something obvious (though highly unlikely). There is still water in the machine (from when it cut out during a cycle). How would I empty this (without electric) and ensure it is safe to look inside? Does it need discharging like a PC?
Root Admin Whitegoodshelp Posted June 6, 2012 Root Admin Posted June 6, 2012 I would unplug it and leave it several minutes before touching it as they can hold a small charge in a capacitor. There's advice on draining a washing machine in this article - Washing machine won't empty water (stuck full of water) Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
