Hello community, i'm hopeful that you can give me some advice.
I'll spare you the boring details, i'll just say I have a 3 year old boy and i'm 99% sure a penny has been put down the pipe where the detergent goes.
My washing machine is a BEKO WM 5100 bought very recently.
My question is: Should I take action regarding this penny before I use the machine? Will it cause the machine damage if I leave it be?
Well thanks for your time....Oh and 3 year old boy free to a good home, fully toilet trained ;)
Aimee
It's a bit like Russian Roulette. The chances are it won't do any serious damage but it certainly could. It will behave completely randomly once inside. It could easily just end up inside the sump hose or pump filter and never be heard of again. But if it gets tipped on its edge and the revolving drum hits it then it can cause serious damage to the plastic outer tub.
If it were me I would disconnect the machine and tip it back and forth and from side to side to see if I could hear it sliding around in the tub. It's possible to get a coin to drop into the hole at the bottom of the tub into the sump hose. Once there it shouldn't be able to cause any serious damage. If you've already used the washing machine since, it could already have got into the sump hose.
Check the pump filter in case it's there. If you aren't going to try and find it or get an engineer out you need to listen carefully to it for the next several washes and if you hear it clanging about stop using it and try to get it out by the method I suggest or call an engineer.
Here's a useful article - how to find something stuck in washing machine drum
Thanks a lot for the reply. I have not used the washing machine at all since so I think we'll take your advice. I'll let you know how we get on.
Thanks again :)
