I have a Candy CMD146.
Mid-way through the washing programme at the point when It should spin dry, instead of the machine building up the spin
speed it spins at max speed. This causes the machince to voilently wobble which stops the machine from running, It then
tries again at running max speed, this repeats until the machince has had enough and stops completly and flashing lights
appear.
On occasions the machine behaves itself and does a full programme without problems, but 90% of the time it fails.
It is not affected by the amount of washing I put into it.
I'm trying to find out which part is most likely at fault and buy and install that part.
  • 1 year later...
Worth checking this article out as fault sounds like the washing machine can't balance the load well enough to spin - if it isn't the loading there may be a fault on the out of balance system - won't spin small loads
