Showing results for tags 'water inlet'.
  1. I noticed the other day that my machine is not taking warm water into the main right hand compartment, it's taking just cold water into the left one. I automatically assumed the program mechanism. However, I removed the hot water pipe to the machine, and the pressure is high. Reconnected the main hose, disconnected rubber hose from inlet valve to the soap compartment. Switched on and water drizzled out. No pressure at all. So, I am now confused, thinking of changing the inlet valve which is obviously faulty. I have no idea if the machine will take cold if the warm is not working properly? I don't think it's the program mechanism, it's a mechanical type which would be a huge coincidence if it fails the same time as the inlet valve. Much appreciate any comments.
