Showing results for tags 'replacing timer'.
  1. The belt came off my WD64 and this took out the wiring around the mains filter that managed to wrap the Green/Brown wire off the mains filter around the pulley. The next bit is all my fault because I made an assumption and didn't look properly in poor light. The other end of the wire had been pulled off the mains push button switch and I had to remove the timer to find it, in doing so I assumed the plastic plugs connected to the timer will only fit in their respective places so I didn't notice that the top two blue plugs are interchangeable. One blue plug has all white wires to it and the other has all black wires. There was a big flash/bang when I turned on the machine as two tracks on the timer evaporated, fortunately I have another timer. Can anyone help?
