Showing results for tags 'replacing drum lifters'.
  1. I not sure what the part is called exactly but one of the plastic paddles inside the drum keeps falling out. It will lock in to place securely but then after one or two washes will come loose midcycle. Even replacing the part has not solved the problem.
