Showing results for tags 'replacement inlet hose'.
  1. Hi I saw the following advertised as an inexpensive replacement for the waterproof inlet hose system that Miele uses. Does anybody have an opinion about it's reliability? Is it available more cheaply elsewhere? Thanks for any help. MIELE CONVERSION KIT FOR WPS INLET 1 X CONVERSION KIT FOR THE W800 & 900 SERIES WPS AQUASTOP MACHINES. MACHINE NOT FILLING? LIGHTS FLASHING ON FACIA!!!...THE BIG QUESTION IS..IS IT THE AQUAHOSE AT FAULT?...COST APPROX £190+ ..OR THE TRIPLE INLET VALVE?..COST APPROX £100+. OR BOTH??? THIS IS GETTING EXPENSIVE ON A 15+ YEARS OLD MACHINE. NOT TO WORRY...THIS KIT REPLACES THE INLET HOSE FOR A NORMAL TYPE..IT ALSO REPLACES THE TRIPLE INLET VALVE. SO FOR LESS THAN £70 YOU HAVE SOLVED THE PROBLEM, AND REPLACED THE INLET SYSTEM. IF YOU EVER NEED ANOTHER INLET HOSE YOU CAN POP DOWN B£Q AS ITS A STANDAND WASHING MACHINE HOSE. YOUR MACHINE WILL STILL HAVE THE ANTIFLOOD DEVISE WORKING UNDERNEATH BUT IT WON'T NOW COVER THE INLET HOSE.BUT LETS BE HONEST WHEN DID THAT LAST LEAK IN THE LAST 15 ODD YEARS? KIT CONSISTS OF 1 X 2.5M COLD INLET HOSE 10 BAR 25DEG MAX.3/4ins BSP ends 1 X TRIPLE INLET VALVE (+SPECIAL COVERSION PLATE) 3 X JUBILEE CLIPS THSI KIT IS MADE FOR THE W900 SERIES ONLY W902 W906 W916 W919 W930 W931I W937 W939 W969 W970 W980 W989I
