I have a Hotpoint WMAQF641 AQUARIUS, not long had it but recently kept showing an F15 error which i believe is to do with pump. for a while when msg showed i could stop machine and start again manually and set it to spin + drain. after a few days the pump propeller stopped, leaving water in machine so it would not drain and spin. I have had the pump out and someone connected it for me outside machine and it worked and spun, but as soon as i put the pump back into washing machine it does not propel. doe's this mean the problem is with the computer then not the pump. I would of been happier if the pump was faulty then at least I'd know for sure.
Cheers
Neil
