Showing results for tags 'pump will not run'.
  1. Hi, I hope someone can help, I have an Indesit 6125 that will not empty the water, I have had to empty the water by tilting the machine back and taking the inspection panel off, the pump was not blocked at all. I removed the pump and checked it out with a meter which was ok, I also put a 240v supply on the pump and it ran very well with no noise or vibration. I can only assume that the machine is not sending power down to the water pump. After emptying the machine I tried to run it through another wash cycle which it does ok until it has to empty the water and then the same problem comes up - all the lights flash and the machine stops. Any ideas would be welcome as I have two young kids and the washing is piling up. Many thanks
