Showing results for tags 'power light only'.
  1. I have a Zanussi WJD1667 W Jetsystem washer/dryer. I moved around a week ago and one of the removal guys put the washer in place and connected it to the drain. I was doing a washing a couple of days later and the machine wouldn't drain? I had to end up taking all the water out manually. I thought it was the drainage pump that must be faulty. I got it down on it's side and checked it and the pump looked ok. (quite a lot of water came out) I bought a pump anyway. Haven't fitted it, because the only thing that works now is the power light (which is a press on/off switch) The LED display's not working at all. I don't know where to start. Could it be that something has got wet? I checked the PCB and there's no marks on it like burning or anything, it looks pretty clean. Is it time to send my old favourite machine to a better place or can it be salvaged. I love this washer it's never gave me a days bother in all the years I've had it. I forgot to mention the removal guy that put it in forgot to check that the connection to the drain under the sink wasn't capped (It was so the machine couldn't drain) A plumber that was out commissioning my boiler asked if I had checked it? I said no, I had assumed the removal guy must have checked. After that the machine started to fill and wouldn't stop...another flood.Then all the LEDs stopped working and I'm just left with the power light on and nothing else now. So is there any hope? The machine was working perfectly fine before all this palaver.
