Showing results for tags 'not working'.
  1. Hi, my indesit WIL 82 has stopped working. Got home yesterday to find it steaming madly. It had heated the water soon much and for so long that the plastic drawer had deformed. How the washer turns on and the power led flashers away no matter which bottoms you press. At this stage the door does not lock or the machine does not start. You need to turn it off at the wall and back on again - then the door locks and the cycle starts without any bottoms being pressed. When its set to a wash cycle its pumps water in and washers, pumps water out and stops after approx 5 mins with power led flashing and that's it. The stage led's (indicate what cycle the machine is in) are not appearing at all though this cycle. They are also not no at start up. Can anyone help with a fix to this problem please?
