Showing results for tags 'miele w2104 check drain'.
  1. Purchased a used Miele washing machine several months ago and till recently it's been awesome. Recently got the Check Drain, which I did. Nothing whatsoever in the drain area, quite clean. Didn't solve the problem so I repeated the procedure a few times. Ordered a good used as well as brand new pump. Replaced pump twice, did not help, pumps do not spin. Tried leaning machine at 45 degrees to get rid of moisture from repeatedly opening drain. Still same issue. I did see a suggestion somewhere that an inlet valve may set this warning, but I don't understand how, since the machine fills up fine and it's the pump motor not spinning. Sometimes since this started there's an unusual "clicking" near the detergent drawer just after a cycle is commenced. After buying multiple spare pumps I'm still keen to fix this machine...
