Showing results for tags 'miele w 5780 leak seal'.
  1. Hi all, My W5780 alerted me to a "waterproof fault" i.e. the bottom of the machine had pooling water internally. I've traced the leak to the black rubber "water path seal" between the water inlet valve and the mechanism behind the dispenser tray. As the machine fills, water is being pushed out backwards from the dispenser tray, forcing the seal (which doesn't have any clamp) to leak. Any advice please? All other electrical and mechanical systems are working fine. Seal looks good when removed. Could blocked nozzles or something inside the dispenser tray be allowing pressure to build in the incoming water and forcing it back out? Be so grateful for any help - we have health issues in the family and can't really allow an engineer in to repair during Covid-19 outbreak. I'm a decent home mechanic and electrician, so given a steer I can probably solve it myself - I just didn't want to dissassemble the machine further than necessary without some advice! Thanks.
